Post by chriscurtin on Apr 19, 2019 20:01:39 GMT -5
Hi,
I'm upgrading to a real Garrett t3/t04e 50 trim and the next issue I've encountered I can't work around: the oil feed hole is much larger than the 90 degree fitting that I used with the stock t3.
This is the fitting from your oil feed line into the top of the turbo.
I took the turbo to Lowe's and couldn't find anything that fit, either bolts or in the plumbing section (though they do have a limited selection).
So any idea what size that oil feed hole is? And what size is the male part that goes to the braided line from your oil feed line?
Thanks
Chris
Post by Stinger on Apr 20, 2019 1:20:33 GMT -5
Post by chriscurtin on Apr 20, 2019 8:25:59 GMT -5
Thanks Shannon!
