Post by Stinger on May 28, 2019 23:30:33 GMT -5
Post by Stinger on May 29, 2019 10:52:34 GMT -5
It will act exactly as you described in the first post. Not with a small leak but with a moderate leak. It's a very common problem.
Post by Stinger on Jun 2, 2019 12:03:19 GMT -5
There is a small paper/cardboard gasket that seals the housing to the backing plate. I've actually made a new one out of a cereal box before (make the inner and outer diameter circle and draw them onto the box and cut it out).
Post by Stinger on Jun 2, 2019 16:46:38 GMT -5
What other issues? There are only a few things that would make it a good idea to spend $700 on a new turbo.
We don't sell turbos. The stock turbo is a REALLY good match to the stock engine so if we can avoid replacing it then that would be ideal.
Post by Stinger on Jun 3, 2019 3:41:53 GMT -5
The stock turbo is a Garrett T3 and it's got an angled inlet that bolts on with 2 bolts.
There are rebuild kits available for around $100.
Post by Stinger on Jun 8, 2019 17:48:01 GMT -5
What codes do you get when you check them?
Post by Stinger on Jun 10, 2019 14:51:06 GMT -5
That's certainly problematic. Is there a functional check engine light?
Post by Stinger on Jun 10, 2019 21:38:29 GMT -5
The ability to scan for codes tests every sensor & the wiring for the entire system. Even if there are no codes, that at least tells you it's a mechanical issue, not something related to the ECU/harness/sensors. Without that info, nothing an be eliminated. So ideally you either find the diagnostic port or add one. I'd have to look it up but it's likely you can ground a pin or two at the ECU to output the codes through the check engine light without adding the diagnostic port wiring.
What harness is it? I've never heard of an aftermarket 2.3 harness for a stock ECU that didn't have a diagnostic port.
Post by Stinger on Jun 11, 2019 12:47:27 GMT -5
How difficult a new harness is depends on wire routing for your application, whether the stock harness length was retained or not, how comfortable you are with basic wiring (connecting power wires, ground wires, gauge signals, etc.). The rest is just plugging in connectors.
Post by Stinger on Jun 16, 2019 21:35:56 GMT -5
The PiMPx doesn't use the diagnostic port so in a roundabout way that "fixes" that problem.
You'll need to test the three TPS wires to verify you've got ground, 5v, and variable (close to 1v closed, close to 5v wide open). It was likely not plugged in because the previous owner had the same issue and decided the easiest "fix" was the unplug it.
Post by powerstroke98 on Sept 23, 2019 19:42:40 GMT -5
I’m having a issue where in start to miss and buck when I start to build boost any ideas?
Post by Stinger on Sept 23, 2019 20:27:36 GMT -5
Not with the lack of information provided. The only info I have to go along with your question is you've got a 98 PowerStroke. I don't know what engine you're working on, ECU type, or anything else.
