Post by turborockkrawler on Jul 12, 2019 18:09:07 GMT -5
Old reused parts T3t4 turbo Exhaust manifold might build new Pimp ecu Ron harness Ported lower intake 60lb injectors Stinger fuel rail Cj pony bbk regulator Stinger pressure regulator adapter Meth injection New Need help picking Piston Rods Head solid lifters and ported Rings Oil pump Upper intake stainless Better water pump Coil on plug set up Stinger distributer trigger Android gauges and data log Figure out boost solinoid
Anything else to bullet proof
Post by Stinger on Jul 13, 2019 1:24:18 GMT -5
What sort of power are you wanting to make and what RPM range is most important for power?
