4banger
BANNED
Post by 4banger on Feb 28, 2010 20:34:38 GMT -5
check the timiing and its wright on. i am going to check the fuseable links tomarrow. i replaced the plugs and wires. my dad thinks maby the dist but i am not sure, this is the first time he really looked at it but he said its fuel. so i gess tomarrow i am going to check the links. and yess i did replace the tensioner kit. i am at a loss. any more idea's
Post by Stinger on Feb 28, 2010 23:44:58 GMT -5
Why did you not check what I said? I stated it twice. Also, which timing did you check?
4banger
BANNED
Post by 4banger on Mar 1, 2010 12:54:39 GMT -5
you said to check the timing and the cam timing which i did, and i made sure the plugs were getting spark. but if i am wrong tell me??
Post by Stinger on Mar 1, 2010 13:32:36 GMT -5
This is what I said: Well, it sounds like it's only running on 2 cylinders. Do you have a timing light? If so, make sure each cylinder is getting spark (put timing light lead on each wire and make sure timing light flashes continuously).
There is also a chance it's just that your spark plug wires are in the wrong order, though I never heard it backfire so it's probably not that. [/size]
4banger
BANNED
Post by 4banger on Mar 1, 2010 17:03:50 GMT -5
ya i did put the timing light lead on each wire and it is getting spark, i just put in new wires and plugs yesterday. I DONT GET IT. would yo u beable to tell any thing if i take a pic of my dist and my ecu, ect ect??
Post by oneowner88lx on Mar 1, 2010 17:21:40 GMT -5
Did you check to make sure the fuel pressure regulator was not leaking fuel through the vacuum line and into the intake? Pull off the vacuum line and does it smell like fuel in there, is it wet?
Are all the spark plugs the same color? A picture of all the spark plugs might help.
Post by Stinger on Mar 1, 2010 19:40:21 GMT -5
I've been asking what the fuel pressure is for over 2 months...never have heard an answer.
A picture of the distributor and plug wires on both sides of engine will let us see if they are in the right order. Pics of the ecu and such won't help anything.
Did you put in your new ECT sensor you bought?
4banger
BANNED
Post by 4banger on Mar 1, 2010 21:40:04 GMT -5
no i have not put in the ect yet, i have ben doing some other test that AFM.co tol dme to do but they did not work. and yes i did check the fuel pressure regulator, it is not leaking gas at all, and yes i will take some pics of the distributor and wires.
Post by Stinger on Mar 1, 2010 23:21:40 GMT -5
Just because it's not leaking doesn't mean it's ok, gotta check fuel pressure to know.
4banger
BANNED
Post by 4banger on Mar 2, 2010 0:31:21 GMT -5
ok i will see if i can get one tomarrow
Post by Stinger on Mar 2, 2010 2:33:38 GMT -5
You don't need to get one, you just need to check the fuel pressure...efi fuel pressure gauges are $15 from harbor freight or ebay. I think someone even put the harbor freight link earlier in this thread.
4banger
BANNED
Post by 4banger on Mar 3, 2010 3:52:35 GMT -5
ok i looked at harbor freight and i think i will order one if i cant get one tomarrow. but here is another vid of the wires and every thing else on my car
Post by Stinger on Mar 3, 2010 13:18:44 GMT -5
4banger
BANNED
Post by 4banger on Mar 3, 2010 21:49:34 GMT -5
i live in libby montana why???
Post by Stinger on Mar 3, 2010 23:22:29 GMT -5
I was just seeing if it was a place where a lot of turboforders live...clearly it's not.
