Post by choklos88 on Nov 19, 2019 0:25:58 GMT -5
heres the delima. my stock 2.3 n/a was carburated. i am finishing up my turbo swap and need a feed/return line. what pump are you guys using or am i misiing something. i have my bed removed. crossing my fingers i can fire her up this weekend after 6months in hibernation. i am using a inline walbro 255 lph. this is a 88 ford ranger
Post by Stinger on Nov 19, 2019 9:38:38 GMT -5
You say you've got a Walbro 255 lph inline pump which is fine for your needs. All you need to do is add a return line or as is often done with carb applications, use the stock carb feed line as the return line and add a larger feed line.
You'll also need an inline filter before the pump. Mounting the pump at about the same height as the bottom of the tank would be ideal.
