joe01
Boosted Newbie
Under construction.
Post by joe01 on Nov 22, 2019 20:49:21 GMT -5
I bought a 1988 turbo coupe with a no start condition after changing the pip,coil,module,cap,rotor,plugs and wires i got it to run with the spout unplugged and throttle on the floor i thought for sure it was a wiring issue and i would fix it when i swapped it into my 1966 mustang but still have the same problem? Any ideas??
Post by Stinger on Nov 22, 2019 21:42:54 GMT -5
What ECU?
Removing the spout removes the ECU from the spark equation.
joe01
Boosted Newbie
Under construction.
Post by joe01 on Nov 22, 2019 22:41:39 GMT -5
Pimp micro squirt 1.2
joe01
Boosted Newbie
Under construction.
Post by joe01 on Nov 22, 2019 22:55:09 GMT -5
What ECU? Removing the spout removes the ECU from the spark equation. so basically if i don't find a problem with the spout wiring the problem is the ecu?if so can it be fixed or am i looking at buying a new one?
Post by Stinger on Nov 23, 2019 0:53:18 GMT -5
Yes, and they can be repaired.
joe01
Boosted Newbie
Under construction.
Post by joe01 on Nov 23, 2019 7:13:08 GMT -5
Ok i guess I will check the wiring today and keep my fingers crossed. Thank you
