Post by jimtash on Jan 16, 2020 5:03:46 GMT -5
I'm going to replace the clock console panel with a gauge panel in my SVO but want to keep the fog light switch. Since I'm running the Pimp and the fuel grade selector switch isn't used, both relays there shouldn't be needed should they? I want to add a relay for the fog light switch and gain some room if the other 2 relays aren't needed.
Post by Stinger on Jan 16, 2020 14:53:40 GMT -5
Correct, unless you want to use the octane switch for a high/low boost switch at some point.
Post by jimtash on Jan 16, 2020 17:54:39 GMT -5
Thanks man.
