Post by FRANK/TurboTempo on Jan 22, 2010 18:56:46 GMT -5
Save too pc and print it out.
Post by Stinger on Jan 23, 2010 14:08:33 GMT -5
Nice submission, moving to the FAQ section. Thanks.
Post by bobbarker on Feb 20, 2011 23:43:57 GMT -5
How usefull it this mod? Worth the investment in an MSD box for the performance gains?
Post by Stinger on Feb 21, 2011 1:58:43 GMT -5
If you're not experiencing spark blowout then the gain is minimal. MSD's are also horribly unreliable so it's good to avoid running one when possible.
Post by austin on Mar 11, 2014 20:05:27 GMT -5
So how about wiring in the tach. That seems to be the main issue on my experience.
Post by Stinger on Mar 11, 2014 22:14:08 GMT -5
You have a PiMP so the tach should work fine. Do NOT use a tach adapter with a PiMP.
bmf347
Boosting 10 psi
Post by bmf347 on Sept 20, 2015 11:14:55 GMT -5
If using an MSD box with MSD coil, are there any changes necessary to the dwell or ignition settings?
Post by Stinger on Sept 20, 2015 16:20:15 GMT -5
I'm not sure what you're asking. If this is a PiMP related question (I assume so since you can't change dwell with a stock ECU), it should be in the PiMP section of the forum. All MSD info is covered in the CDI ignition section of the startup guide.
bmf347
Boosting 10 psi
Post by bmf347 on Sept 20, 2015 23:53:12 GMT -5
Ok thanks. Must have missed it when I was looking through it. Couldn't find much else on the topic so posted here. Sorry. I'll look through the guide again.
Post by Stinger on Sept 21, 2015 1:00:53 GMT -5
There is a CDI appendix section (has a diagram in it). It doesn't mention dwell settings because it's the same as we set up the base tune for you.
