Post by Carl on Oct 17, 2011 0:51:21 GMT -5
The factory 94-95 5.0 TPS pins out the same as the 87-88 TC.
Post by Stinger on Oct 17, 2011 2:08:20 GMT -5
Correct, but it uses a different connector on the earlier turbofords so like I said previously, it depends what vehicle it's going in.
Post by cjdavid on Oct 17, 2011 7:29:19 GMT -5
I am using an '87 harness from a 4 cylinder, Thanks for the info
Post by Stinger on Oct 17, 2011 11:20:46 GMT -5
Post by Carl on Oct 17, 2011 19:10:33 GMT -5
You will have to swap to the new style connector then. I am running a 93 stang harness and it plugs right in.
madmax
Boosting 15 psi
Post by madmax on Oct 18, 2011 17:34:42 GMT -5
How much could i benifit by swapping over to a 60-65mm Throttle Body. I currently have a 87 ford t-bird turbo coupe 2.3 engine?
Post by Stinger on Oct 18, 2011 23:12:19 GMT -5
The stock throttle body isn't really a restriction below 350rwhp or so. Furthermore, with 2.5" intercooler tubing, the stock throttle body is the same size so flow through each is the same. You really only gain throttle response (because it flows more air when opened a small amount).
