Post by thunderchicken88 on Dec 8, 2008 21:27:52 GMT -5
I do need to know if i need a bigger bore oil line or if i can just use that steel braided one i already have. Would it be ok to weld the wastegate closed and use an external one?
Post by Stinger on Dec 8, 2008 22:18:26 GMT -5
The oil line you have is just fine. You can close the internal gate however you want. Bolt it shut, weld it shut, hold it shut with a spring, etc. They all work.
Post by 88turbo on Dec 9, 2008 21:19:36 GMT -5
not sure on the specs Shannon but its one of those turbos that make you personally hang your head in shame I remember talking to you about them while I was at the shop lol
Post by Stinger on Dec 9, 2008 23:49:29 GMT -5
Haha...fair enough!
Post by thunderchicken88 on Dec 14, 2008 23:37:57 GMT -5
I think i need to ask before i continue if im using the right oil or not. Im using quaker state horsepower synthetic. Is it alright to use synthetics in this car or should i go back to my normal QS in the green quart?
Post by Stinger on Dec 16, 2008 11:34:08 GMT -5
Synthetic is fine, it's what I run (well, actually I run Mobil 1 or Valvoline).
