Post by jasonsvolmo on Jan 13, 2021 20:06:45 GMT -5
Sweet, with that said i think the best approach is gonna be following your outline, and see if anything changes. If not will have too send in my kirban, and might as well use a different pressure gauge to double check
Post by ldavis on Feb 12, 2021 18:49:43 GMT -5
I'm going to take a shot at this, are you seeing boost now when you drive the car? Does the car have an intercooler on it? I have had a hose on the intercooler blow off under boost big pop and engine stall will start back up and run but no boost which would explain no fuel pressure rise above what reg. pressure is set at. Just a guess.
