Post by xr4ti85 on Apr 8, 2010 8:05:00 GMT -5
i might be getting a bamafuel setup from a guy and he knows nothing about the system. and he knows it was gotten threw stinger i tried searching on turbo ford and could'nt really find much other then the bad of them going out of buiesness.
and i'm trying to figure out more info. did they come with ms1 or ms2? and were they all setup up for a la3 wiring pin out?
the only things it really says on the case is made on may 16th 2008 2.5 bar map clt ford iat ford
application 91-93 mustang2.3
and other question i was always under conclustion that 14.7 = 1 bar so why on diyautotune does it say 2.5 bar map is for up to 21-22psi? should'nt it be 36.75psi?
Post by Stinger on Apr 8, 2010 11:34:32 GMT -5
It's MS1 extra.
91-93 Mustang 2.3 application should mean it's wired for that, not the LA3.
14.7psi is 1 bar. The catch is that the atmosphere is 1 bar so a 2.5 bar map only gets you 1.5 bar gauge above atmospheric pressure.
Post by xr4ti85 on Apr 8, 2010 11:54:50 GMT -5
ok thanks
Post by xr4ti85 on Apr 8, 2010 12:18:30 GMT -5
ok one more question. sense it's wired for the 91-93 mustang. will it work with tfi? it's going in my 87 merkur xr4ti. right now i have it wired for an la3. so what all wires would i need to change.?
Post by Stinger on Apr 8, 2010 13:18:25 GMT -5
Well, if you could give me the name of the person who originally bought it I may be able to find their original order to verify the wiring pinouts that are built into that ecu.
It will work with TFI as both the TFI and DIS modules work the same from the ECU's point of view. As for wiring...you'd basically be doing a reverse of our 91-93 turbo swap how-to.
Post by xr4ti85 on Apr 8, 2010 13:36:51 GMT -5
i'll see if i can get a name for orignal buyer
Post by bgpickle on Apr 24, 2010 8:16:14 GMT -5
do you want to sell it? i have a 91 and i am installing a 2.3 turbo in that car. i think that is what i'm looking for. stinger will this work for me ? if u don't want to sell it, thats fine. stinger do u know where i can find a system thats better then the stock ecu
Post by Stinger on Apr 24, 2010 10:45:07 GMT -5
If this is the Bamafuel that was on eBay then it appears it's wired for an LA3 converted Mustang.
bgpickle, our FAQ page has a chips and standalone ecu's section that outlines your options for updating or replacing the factory ecu.
Post by xr4ti85 on May 8, 2010 16:33:15 GMT -5
yea it was the one on ebay i did'nt get it though.
