Post by denz on Apr 16, 2010 18:48:19 GMT -5
stinger what software do you run mega tune or tuner studio? what are your likes and dislikes?
Post by Stinger on Apr 16, 2010 19:00:05 GMT -5
Tunerstudio, it's 1000% better than megatune. Matter of fact, it's so much better the new MS3 systems use Tunerstudio as their default tuning program, not megatune.
Post by denz on Apr 16, 2010 19:07:38 GMT -5
so i know witch one im going with. i was looking at willson site and it has hardware and software instructions. Is this were i start? It will be here monday and i have been reading mega man but its to bad im more hands on learner. So mega manual gives me a headache! can you help me tune from there or should i try to stick with scott directly.
Post by Stinger on Apr 16, 2010 23:48:38 GMT -5
Once the car is running/driving with the MS2 and you have the basic stuff setup (Wilson instructions and such) and have the wideband reading correctly on the laptop, it can be tuned through email if necessary. The latest couple versions of TunerStudio has a VE Live function that will tune the fuel (VE) table while you drive around though which is VERY handy. You just have to take it easy and slowly raise rpm/boost and not just go hammer on it initially. You basically have to give it time to figure out what the engine needs at a given rpm/boost level. Just watch the wideband and as long as it's under 12.5:1 under boost, it's safe.
If you want a little more intricate and proper timing table than the unit comes with, you'll have to email me.
Post by denz on Apr 17, 2010 6:58:01 GMT -5
for a wide band do i need a controller or does it hook up to MS. And once i get it up and running i will e mail you. I found a tuner stuido download how do i know it is the latest. If you can direct me to one that would be great. This is going to be fun i love technology.
Post by Stinger on Apr 17, 2010 11:14:30 GMT -5
Post by denz on Apr 19, 2010 13:58:30 GMT -5
it should be here within a hour and i will start to set it up. had a question. do i need my MSD still.
Post by Stinger on Apr 19, 2010 14:21:18 GMT -5
You can still use it for the hotter spark if you want. Well, you can use it for whatever you want, MS2 also has the 2-step, rev limit, etc. though if you were using any of those features.
Post by denz on Apr 19, 2010 20:05:27 GMT -5
well got it put in and it will not connect. I guess i have the wrong usb to serial driver. tried to contact seller to see if he has disc waiting to here back.
Post by Stinger on Apr 19, 2010 22:22:40 GMT -5
Did you try all the different ports on your computer by going into tunerstudio > communication > settings and then changing to com1, com2, com3, etc. and testing each port?
Did you have internet access when you connected the usb cable so it could search for the driver? Did it install a driver automatically or did you install one? What color is your usb/serial cable?
Post by denz on Apr 20, 2010 6:33:42 GMT -5
1. Yes tried all ports 1-20 2. yes it would not find one 3. I installed one driver the one on wilson 4. cable is clear with green conection
I will remove program today and try to let it find one by itself from internet. Any thing you can think of let me know.
dennis
Post by Stinger on Apr 20, 2010 11:53:37 GMT -5
Did you restart the computer and then re-connect the cable? Was the key on for all of this? Did you de-select "work offline" from the file menu in tunerstudio?
Post by denz on Apr 20, 2010 14:07:18 GMT -5
getting out of work and will try again. I will report what happens.
Post by denz on Apr 20, 2010 20:29:44 GMT -5
stinger Yes i did restart the comp after usb cable download from wilson because i did it days before. as far as key off the first time i hooked ms up had key on and laptop on then pluged in USB. When i use de-select "work offline" it comes back with port can not be configured.
Post by Stinger on Apr 20, 2010 21:26:05 GMT -5
What operating system?
