Post by denz on Apr 20, 2010 22:00:45 GMT -5
xp
Post by Stinger on Apr 20, 2010 22:39:16 GMT -5
Hmm, that should be an easy one to get working. It didn't say there were any issues with the driver install?
Does it recognize that you plug in the usb cable and either say it's ready to use or that there was an error and it may not work correctly (box pops up from the bottom right of the desktop).
Post by denz on Apr 21, 2010 6:41:47 GMT -5
when i plug in cable it says found new device, then starts the wizard. does its thing and sercher online or in a cretin local where i tell it to. After not finding it then says here was an error and it may not work correctly (box pops up from the bottom right of the desktop).
Post by Stinger on Apr 21, 2010 11:24:00 GMT -5
OK, so that indicates it's not aware of the driver you installed. Have you used the wizard to browse for the driver and install it from the disc provided by Wilson Racing when it prompts to do so? Does it do so without errors?
Post by denz on Apr 21, 2010 11:29:39 GMT -5
you are good! this is also what i found out. witch is the prob seller did not give me the disc and will not respond to my e-mail. so will yours work and can i use it. or i have to send it to scott. I have emailed him and waiting for a response to see how much.
Post by merc460 on Apr 21, 2010 12:11:40 GMT -5
Post by denz on Apr 21, 2010 12:37:00 GMT -5
merc the usb to serial driver from there does not work. mines older we think.
Post by merc460 on Apr 21, 2010 12:40:49 GMT -5
Well I have the Bamafuel set up if you need it?
Post by Stinger on Apr 21, 2010 14:29:48 GMT -5
My USB/Serial cable is silver with blue ends so it uses a different driver. If you told Scott what colors your usb/serial cable is, he'll be able to get you set up with the correct driver, just give him time to respond or give him a call, he's posted his number on TF a number of times.
Post by denz on Apr 21, 2010 15:33:06 GMT -5
Post by denz on Apr 21, 2010 18:02:45 GMT -5
shouldent this at least prime the fuell pump. Im kind of wondering if this thing is putting out.
Post by Stinger on Apr 21, 2010 22:57:50 GMT -5
That appears to be the correct driver for that cable, it's the same driver I used on my cable when I had XP.
Post by denz on Apr 21, 2010 23:37:45 GMT -5
ya i think it more my laptop than the driver. thursday i will get a long cord and try my desk top. if it doesent work i will have to give up and send it to scott and just wait the two weeks. scott says there all the same cable.
Post by denz on Apr 22, 2010 20:11:09 GMT -5
Ok sending it to scott couple of days and ill have it back. thanks for your help. wont bother you till i get it back. HA HA!
Post by denz on May 2, 2010 18:30:23 GMT -5
on MS2 can you set the tps with software or do you still have to adj manualy with volt meter. Because new tps from tempo reads high at closed throttle. Just getting things set up for when I get it.
