Post by 93lxturbo on May 3, 2010 21:51:26 GMT -5
I have windows 7 on the labtop and its not installing on it, any ideals
Post by Stinger on May 3, 2010 22:56:42 GMT -5
What's not installing? The USB driver? The tuning software?
Post by 93lxturbo on May 4, 2010 4:24:40 GMT -5
The USB drivier is not installing.. scott said all i need was to install the 3 files from folder RS-232 but it saids USB-232 but the last folder want in install.. and the 2nd one you have to pick windows xp or vista.
Post by Stinger on May 4, 2010 10:42:05 GMT -5
Post by denz on May 4, 2010 20:12:08 GMT -5
The one from wilson did not work for mine with xp I had to send it to scott. hope to get it back this week.
Post by 93lxturbo on May 4, 2010 20:21:15 GMT -5
when i go to new project and hit detect its saying no device found.. Scott's saying go to add hardware but i cant find that on windows 7?
Post by Stinger on May 5, 2010 0:54:43 GMT -5
Did you not read what I said above? It can't detect a damn thing until you install the driver I posted above. Without that driver, no information will go through the cable that connects the MS2 to your laptop.
Post by 93lxturbo on May 5, 2010 16:58:46 GMT -5
OK i got it to work on my sister laptop its wins xp.. but im needing it to work on mine.. the file HL-340 will not install on windows 7. its the file from the disc
Post by Stinger on May 5, 2010 21:45:36 GMT -5
Well, since you won't use the link I've provided for you and instead keep using the disc that's for XP, I don't have any other way to help. I tried...
Post by 93lxturbo on May 5, 2010 22:05:11 GMT -5
that that you gave me is installed and there are no com port that i see.. its saying driver not installed?
Post by Stinger on May 5, 2010 22:34:11 GMT -5
Plug in the cable, see what com port is listed for it.
Post by 93lxturbo on May 5, 2010 22:46:37 GMT -5
i will show you in just a min..
dizzle
Post by dizzle on Sept 11, 2010 17:42:57 GMT -5
93lxturbo , is your laptop an Assus? Did you ever get it to work with Windows 7?
