radguy
Boosting 15 psi
Post by radguy on Jul 14, 2010 23:59:14 GMT -5
I was messing around with my camera mount and took a video when I was out tuning. Its not much but it gives you the idea of how it runs. Picture: Video: Dan
Post by Stinger on Jul 15, 2010 1:22:33 GMT -5
Glad to see my timing table worked so much better than the one that came with the MS2! Sounds like it's running good and smooth now.
P.S. I fixed your links so they would show up.
radguy
Boosting 15 psi
Post by radguy on Jul 15, 2010 11:27:38 GMT -5
What was the deal with the link? Once again thanks for your help.
Dan
Post by Stinger on Jul 15, 2010 13:36:07 GMT -5
I used the "tube" button above the text box to make it where you can view the video without going to youtube. Just highlight the video link and hit the red "tube" button and it puts the code before and after the link.
[youtube]http://www.youtube.com/watch?v=JguI5kdfwRQ[/youtube]
For the pic link, I got rid of all the "extra" flickr crap and just used the actual picture link with image codes around it: [img]http://farm4.static.flickr.com/3475/3975145089_d67f539d1f.jpg[/img]
Post by 93lxturbo on Jul 17, 2010 8:25:18 GMT -5
i will change it to your setup. will it run 20psi. just about everything on my ms2 kit is the way it come..
Post by Stinger on Jul 17, 2010 12:38:39 GMT -5
Every engine setup is different so I'm not saying the timing table I outlined is "perfect" for your engine. It's a whole lot closer than what you are running now though. If it detonates you need to remove a few more degrees of timing in the area it's detonating until it stops. It should allow you to run 20psi though.
Post by 93lxturbo on Jul 17, 2010 14:29:05 GMT -5
btw nice ranger
Post by ncsquirrel84 on Apr 20, 2015 19:10:04 GMT -5
Good to see I'm not the only boosted ranger.
