Post by coreydaniel on Aug 6, 2010 10:39:56 GMT -5
i went to the dyno last night and had pleasing results. It put down 299.6hp/309ft lb to the wheels. The AFR stays between 11.5 and 12.2. The power drops off after about 5700rpm because it got so rich. I need to tune it some more in the higher rpm. I think there is more power there.
Post by Stinger on Aug 6, 2010 13:25:42 GMT -5
Nice, what's the setup?
Post by coreydaniel on Aug 6, 2010 14:02:08 GMT -5
home ported and polished head, boport 1.5, 72lb injectors megaquirt from Wilson racing, holset hy35 mounted on an E6 that is home ported, ported inake, spearco front mount with 2.5 IC pipe, full 3in exhaust from turbo back with a thrush muffler. I was going to send you the data logs from the dyno pulls. Id like to get it leaned out past 5700rpm, i really think it will help it it.
Post by Stinger on Aug 6, 2010 14:16:21 GMT -5
Do you use TunerStudio or Megatune for tuning? You can send the datalogs but be sure to send the .msq and the firmware version as well.
Post by coreydaniel on Aug 6, 2010 21:28:51 GMT -5
emails sent. I included the datalog, tune(msq) and the version info
Post by coreydaniel on Sept 18, 2010 12:17:01 GMT -5
Took my car to the track. On the low boost tune (18psi) it ran a 8.48 at 88 mph. I didn't have the gas to turn up the boost but I will next week. The sixty coot was decent at 1.76. The big tune up (26psi) should bring it down quite a bit
Post by Stinger on Sept 18, 2010 17:28:36 GMT -5
Sounds good!
Post by Matt Culpepper 2300gearjammer on Sept 18, 2010 21:31:56 GMT -5
Holy cow. Great et. Its definitely going to be rocking when you get it cranked up.
Post by coreydaniel on Sept 20, 2010 17:06:08 GMT -5
I have watched several videos of the black stinger bolt on car. What is being used for suspension on it? I would really like to get my car to pull wheels, or at least one wheel. Ive obviously got the power, but im not sure what to do with the suspension. It is hooking so good im kind of affraid to mess with it. The front comes up now, but the rear doesnt squat at all.
Post by Stinger on Sept 20, 2010 23:03:31 GMT -5
The Bolt-On car rear suspension was basically just stock style with an airbag in the passenger side. Front was worn out Koni struts and a tubular k-member. It's best 60ft was a 1.52 I believe and was typically 1.57-1.60.
Post by coreydaniel on Sept 21, 2010 6:30:14 GMT -5
Ive been considering a tubular k member. I think im going to go with the UPR kit that comes with k member, lower ctrl arms, and a coil over kit. I couldnt find any negative feed back on it
Post by bobbarker on Sept 21, 2010 6:37:59 GMT -5
I've got the UPR tubular K member w/ coil overs in my car, no issues with it. Looks great and makes working on the car from the bottom so much easier!
Post by coreydaniel on Sept 21, 2010 10:49:36 GMT -5
Im glad to hear that. I havnt found anybody who has done it to a 2.3 car. Everyone has a 5.0 that i have talked to with the tubular members. Im hoping the whole kit will lighten the front about 50lbs or so. Do you drag your car or just drive it? im wondering how good the spring rate is with the coil overs
Post by bobbarker on Sept 21, 2010 12:50:19 GMT -5
I haven't been to the drag strip in it yet, still probably won't for a while now either.... I'm not sure on the spring rates... I really can't compare it to anything else 4cyl, or even fox body for that matter... so in summary, I'm not much help at all!
Post by Matt Culpepper 2300gearjammer on Sept 21, 2010 17:41:31 GMT -5
You'll be amazed. Its way more than 50lbs. The factory kmember is an awkward heavy mess and I put the tube kmember, control arms, struts, spindles, and complete brake assembly all under the black car as one unit.
As for figuring out a spring rate. The correct way is to put some kind of spring in it, set the height where you want it to be and then weigh the car on individual wheels scales. From there you can decide what you want. The black car has a 14" 115lb spring. The nose is pretty light so it works but I preferred a touch stiffer. Everything else was on backorder everywhere at that time.
