Post by coreydaniel on Sept 22, 2010 10:45:52 GMT -5
I have a tubular k memeber set up for a 95 mustang, im not sure if it will work though. I got a car that someone started and never finished. Got a lot of good parts, but im not sure how much of it will work on a fox car. I think i may try it and see.
Post by Matt Culpepper 2300gearjammer on Sept 22, 2010 12:33:09 GMT -5
Most companies list them from 79-04 so I'd bet $1 it would work fine. Especially if you have all the components to accompany it.
Post by coreydaniel on Sept 22, 2010 17:11:50 GMT -5
yeah it has everything, kmember, coil overs, lower control arms, bump steer, caster camber plates. I hope it works, i still need to get the parts car to my house, it is currently still in storage. I think i may try to get it this weekend, sounds like a good weekend project,lol
Post by Matt Culpepper 2300gearjammer on Sept 22, 2010 19:38:53 GMT -5
Yeah you should be good to go.
I ended up leaving the CC plates off when I swapped everything to mine. Was this a track only car?
Post by coreydaniel on Sept 23, 2010 6:25:45 GMT -5
The parts car was a track only car. But i drive my car every weekend and sometimes during the week.
Post by 93redgt on Mar 24, 2011 11:46:59 GMT -5
from what i have seen the sn95 k-member is slightly different than a fox, the bolt holes are slightly off, could you make it work, im sure you could make it work though
