Post by Stinger on May 17, 2011 0:09:31 GMT -5
Can you plug the pimp into a merkur harness with out re-pinning? Yes
Post by n20capri on May 18, 2011 14:59:09 GMT -5
Can someone post more detailed instructions on how to wire AEM 30-2310 into the stock connector please? I should be PiMP'n soon - I got my tracking #. WOOT WOOT...
Post by Stinger on May 18, 2011 16:31:22 GMT -5
Post the link to the directions from their site and I'll take a look at it this evening.
Post by n20capri on May 18, 2011 18:35:24 GMT -5
It's the sensor you recommended...lol I was looking for more detailed on what you said below earlier in this thread... Someone gave a quick rundown on what needs to be done I was just looking for more... This is what they provide... www.aemelectronics.com/Images/Products/Installation%20Instructions%2030-2310.pdfThe 30-2310 is the easiest to hook up to the PIMP and we will offer directions for using the factory 02 sensor wires so you don't have to run any wires through the firewall.
Post by Stinger on May 18, 2011 22:50:38 GMT -5
Post by n20capri on May 19, 2011 8:15:59 GMT -5
Ahhh cool thanks
Post by n20capri on May 23, 2011 16:04:50 GMT -5
Does the vacuum port need to be connected in a Naturally Aspirated application? Thanks
Post by Stinger on May 23, 2011 18:30:53 GMT -5
Yes, the MAP sensor needs a signal regardless of application.
Post by n20capri on May 23, 2011 19:55:16 GMT -5
K thanks!
Also, should the PiMP ecu buzz or humm with key on? When I had key on looking for O2 power it was humming...
Post by Stinger on May 23, 2011 22:24:03 GMT -5
I guess that depends on how loud the buzz was. If it's something you could hear more than a few feet away, no.
Can you please ask PiMP tech questions in the PiMP tech section of this forum? I've already moved 3 of your posts there and asked you to do so via PM.
Post by real merkur 87 on Oct 29, 2013 12:52:23 GMT -5
Hello stinger , could u pl tell me or give me directions on how to wire the lc-1 db gauge to the ecu or to the 29 pin on the ecu. so I can get a reading. Im ready to try and start this car after a long hard road. Thanks
Post by real merkur 87 on Oct 29, 2013 12:55:51 GMT -5
Hello stinger, could u pls tell me or give me directions on how to wire the lc-1 db gauge to the ecu or 29 pin. So I could get a reading. Im ready to try and start this car after a long hard road. Thanks
Post by Stinger on Oct 29, 2013 12:59:20 GMT -5
Post in the PiMP section of this forum. The question is answered in the PiMP Startup Guide. This thread has not been used since 2011 and it's not for tech support.
