Post by boostgobbler on Dec 21, 2008 23:22:19 GMT -5
Can anyone tell me what size AN fitting i need for my WH1C oil feed line? Its from a 94 dodge if that helps.
Post by Stinger on Dec 22, 2008 4:33:04 GMT -5
Holset turbos require you to purchase a 12mm x 1.5 to -4AN adapter Summit racing part # EAR-9919BFGERL
Post by boostgobbler on Dec 22, 2008 12:58:03 GMT -5
Excellent! Thanks for the quick responce! One more question, iv seen som debate about using an oil restrictor on the holsets and im just wondering what you think. Does project bolt-on more use one?
Post by Stinger on Dec 22, 2008 21:39:38 GMT -5
We don't run a restrictor.
Post by maverick88tc on Jan 23, 2009 10:05:15 GMT -5
i couldn't find anyone to tell me what size that was on mine. i ended up retaping the inlit to quarter inch npt. and using a brake line oil feed
Post by boostgobbler on Apr 15, 2009 11:44:36 GMT -5
Ok guys, i ordered the adapter stinger recommended and its to small on the turbo side, i put a 14mm rethreader in there just to see how much bigger it was and it was to small too. I think its a 15mm or a 16mm, i checked what earl sells on summit and i didnt even see a 15mm only a 16mm and it was attacted to a -6 an and there was no smaller option. So if a -6 AN to 16mm X 1.5 is all that i can get then would it be ok to just use a -6 line instead of -4? Any suggestions?
Post by Stinger on Apr 15, 2009 12:21:20 GMT -5
No, just adapt it down to -4.
Post by boostgobbler on Apr 15, 2009 14:44:03 GMT -5
You wouldnt happen dto have a part number would you? I am having soe trouble finding this adapter.
Post by boostgobbler on Apr 15, 2009 15:57:38 GMT -5
Nevermind i found it!
