Post by Stinger on Mar 31, 2011 0:39:17 GMT -5
Huh? Do you have the hold down rings under the bolts? There should be half round plates with three holes in each one that clamp the center section and exhaust housing together.
Post by bobbarker on Mar 31, 2011 20:36:41 GMT -5
Yeah, three hold down rings (only 2 holes in each, total of 6 bolts) all tight as I can get them. It's odd, when I replaced the bolts in the exhaust housing several months ago with new stainless hardware it fit tight and no movement noticed. Not it just turns and moves side to side.
Post by Stinger on Mar 31, 2011 22:28:21 GMT -5
And the bolts are still tight? I can't think of any way how that's even possible. Pics/Vid?
Post by bobbarker on Mar 31, 2011 23:24:33 GMT -5
I can make a short vid this weekend. So long as I'm not being my normal lazy self.
The bolts are as tight as I can get them. The one that is hardest to reach is on the side near the head, bottom just next to the oil drain tube. It's tight, but hard to really crank on. All others are in solidly.
Post by Stinger on Apr 1, 2011 0:15:45 GMT -5
And the center section is moving relative to the exhaust housing correct?
Post by bobbarker on Apr 1, 2011 0:23:42 GMT -5
Yes, the center will rotate clockwise and counter clockwise, and even rock a little "back and forth" from side to side. It's kind of hard to explain, I'll try and get that video this weekend.
Post by bobbarker on Apr 7, 2011 20:22:26 GMT -5
Well I still haven't made any video on the turbo moving inside the housing... but I did make this! Removed the 2 gauges off the pillar to where the radio used to be. I started with a shiny, nicely cut 8"x3" piece of stainless I found at scrap at work. Turned into this with a plasma cutter, hammer, and some drimmel cut off wheel scars! I LOVE the way it looks!
Post by bobbarker on Apr 7, 2011 20:24:16 GMT -5
I'm going to leave that 3rd hole just like that. I don't think I'll be putting any other gauges in and I like the way that hole looks all raw and uneven!
Oh yeah, that old fuel gauge was WAY faulty! New one reads at 60psi!!! Maybe some of the reasons the car was cutting out at high RPM's.
Post by Stinger on Apr 7, 2011 22:45:20 GMT -5
As long as you like it...
Post by bobbarker on May 28, 2011 13:53:14 GMT -5
dizzle
Post by dizzle on May 28, 2011 14:18:44 GMT -5
Looking good! WAY WAY better than those funky red stripes!
Post by bobbarker on May 28, 2011 16:15:03 GMT -5
Ha! Those funky stripes were red, purple AND dark blue! I never found out where that came from, it wasn't an original from Ford, probably from a dealer that first sold the car. I searched for a while looking for an original seller but no luck.
Post by 75pinto on May 28, 2011 21:10:13 GMT -5
just curious, where in florida ya at?
Post by bobbarker on May 29, 2011 7:09:57 GMT -5
Just a little north of Orlando. Small town called Lake Mary.
Post by 75pinto on May 29, 2011 14:08:16 GMT -5
i know the spot. I am in St Augustine, and i have drove i-4 many a time. maybe we can meet up at the track at orlando or gainesville sometime
