jaidedeye
Boosting 15 psi
Big Turbo SVO
Post by jaidedeye on Nov 5, 2010 22:56:29 GMT -5
Post by Stinger on Nov 6, 2010 2:47:11 GMT -5
What numbers for what? For the size of the exhaust housing? You look for a "18cm" or similar cast into the exhaust housing.
jaidedeye
Boosting 15 psi
Big Turbo SVO
Post by jaidedeye on Nov 6, 2010 10:21:53 GMT -5
What numbers for what? For the size of the exhaust housing? You look for a "18cm" or similar cast into the exhaust housing. just my luck..ugh...i looked....and dammit, its a 21cm.....im assuming thats entirely too big right?
Post by Stinger on Nov 6, 2010 10:53:00 GMT -5
Only one way to know for sure...bolt it on and see what you think...mainly depends on how many airflow mods you have.
Post by bobbarker on Nov 6, 2010 15:41:04 GMT -5
Is the "rash" on one of the fan blades an issue? just for my own future reference.
Post by Stinger on Nov 6, 2010 23:20:35 GMT -5
I don't see any rash unless you are referring to the paint stripe they put on all new turbos so you can see they are spinning...actually I don't know why they put the paint on there but they always do!
jaidedeye
Boosting 15 psi
Big Turbo SVO
Post by jaidedeye on Nov 7, 2010 0:27:47 GMT -5
Only one way to know for sure...bolt it on and see what you think...mainly depends on how many airflow mods you have. think thats what im gonna do....air flow mods will be ported upper and lower intake manifold, 65mm SN95 throttle body..boport stage 3 head with 2.5 cam...
jaidedeye
Boosting 15 psi
Big Turbo SVO
Post by jaidedeye on Nov 7, 2010 0:29:24 GMT -5
Is the "rash" on one of the fan blades an issue? just for my own future reference. its paint on the blade...they use this as a reference marking when balancing the assembly
Post by bobbarker on Nov 7, 2010 16:17:51 GMT -5
oooooh.
