93 lx
Mar 1, 2011 15:19:20 GMT -5
Post by frankd2054 on Mar 1, 2011 15:19:20 GMT -5
parts list: ranger 2.5 cam, hopfuly better one soon svo head poeted and cut valves trick flow springs gutted intakes stinger front mount and pipeing kn filter holset hx35 turbo stinger header stinger 3in down pipe 3in custon mid pipe borla 3in in and out muffler diamond pistons high flow oil ands water pump 255 fuel pump la3 comp round tooth time set swap t5 trany 8.8 rear with 3.73s alum driveshaft 2 step and msd full ignition and some other thing im forgeting
93 lx
Mar 1, 2011 23:22:29 GMT -5
Post by bobbarker on Mar 1, 2011 23:22:29 GMT -5
That's a pretty nice mod list there! Any performance numbers to go with it?
93 lx
Mar 2, 2011 6:47:30 GMT -5
Post by frankd2054 on Mar 2, 2011 6:47:30 GMT -5
fastest et: 12.8 at 108mph and somewhere in the range of like 350 wheel horse
93 lx
Mar 2, 2011 13:47:18 GMT -5
Post by Stinger on Mar 2, 2011 13:47:18 GMT -5
What's Ranger 2.5 cam?
What size injectors? If they are stock then the rwhp didn't exceed 300 or so (not that it matters). That would match your ET/MPH better as well.
93 lx
Mar 2, 2011 15:27:48 GMT -5
Post by frankd2054 on Mar 2, 2011 15:27:48 GMT -5
im not sure the hp on the car. i never tryed to see the hp but the ranger 2.5 cam is the roller setup out of a 2.5 ranger the injector are not stock i dont rember the size of them
93 lx
Mar 2, 2011 16:54:40 GMT -5
Post by Stinger on Mar 2, 2011 16:54:40 GMT -5
OK so it's the "Ranger roller" from all of the rangers and 91-93 Mustangs.
Are the injectors brown in color? If not what color are they? Light green? Light blue? Black?
93 lx
Mar 2, 2011 20:28:31 GMT -5
Post by frankd2054 on Mar 2, 2011 20:28:31 GMT -5
they are lt blue ones lol and i think they are 25lb ones
93 lx
Mar 3, 2011 0:13:43 GMT -5
Post by Stinger on Mar 3, 2011 0:13:43 GMT -5
You realize you can't just throw different size injectors in and it work properly right? If they are 25lb, you are getting nearly 40% less fuel flow than it should. Lt blue "could" be CFI injectors which would be 42lb. These "kinda" work with a stock ecu (because they only flow 20% more than the stockers) but they will still cause it to be rich at idle and mega rich at boost onset unless the fuel pressure is reduced (at which point you just turned those 42's back into 35 lb injectors).
93 lx
Mar 4, 2011 19:59:13 GMT -5
Post by frankd2054 on Mar 4, 2011 19:59:13 GMT -5
i relooked at the injectors and they are the stockones but they are a reman style from napa
93 lx
Mar 4, 2011 23:45:32 GMT -5
Post by Stinger on Mar 4, 2011 23:45:32 GMT -5
Ok.
93 lx
Mar 5, 2011 9:15:54 GMT -5
Post by oneowner88lx on Mar 5, 2011 9:15:54 GMT -5
That is a very nice looking car.
