Post by turbojoe on Sept 29, 2011 21:22:41 GMT -5
i cant install firmware on my ms2 i need someone to brake it down for me
Post by Stinger on Sept 29, 2011 22:49:09 GMT -5
You mean you aren't capable (don't know how) or you mean you can't get it to work? If that's the case, at what step do you have issues and what issue is it?
Post by turbojoe on Sept 30, 2011 15:09:39 GMT -5
i dont know how that what i get for going to diy so how much will u charge to put firmware on my ms2 and a base tune
Post by wesk on Sept 30, 2011 22:22:43 GMT -5
Have you read the ms2e guides, or posted on the ms extra forums? What type of computer connection (real serial or usb to serial)? While we obviously offer a plug a play option, the guys at diy autotune are typically quite helpful if you contact them, and are a great company to deal with.
You pretty much just double click on the executable and follow the onscreen instructions. The main concepts) 1) The first time you flash extra code, you need to short the bootloader jumper on the ms2 card 2) The squirt obviously has to be capable of being powered up, either in a car or on a bench.
