Post by Stinger on Feb 18, 2009 1:34:51 GMT -5
I run plugs that are stock for a Saab 9-3 turbo. They are NGK, came gapped to .028 and are a step colder than stock. NGK # BCPR6ES, stock # 2330. I got them from Summit racing.
Post by cupton79 on Apr 13, 2013 7:22:30 GMT -5
which esslinger aluminum head are you running? the D-port l just got called for an autolite 103 which seems to be identical to the stock iron head.
Post by Stinger on Apr 13, 2013 23:05:03 GMT -5
In the past, all Esslinger heads use the same "non-stock" plug design. They may have changed how they machine them. The thing to look for is whether they take a tapered seat, or a crush sleeve on the plug.
Post by cupton79 on Apr 14, 2013 7:11:49 GMT -5
the one l just got takes a tapered plug, like the stock head, according to the plug # they suggested with the paperwork
cbrn
Boosting 10 psi
Post by cbrn on Feb 15, 2017 20:44:45 GMT -5
I have the d port head and use motorcraft sp-406
Post by Stinger on Feb 15, 2017 23:29:36 GMT -5
Yes, they switched to the taper plug design at some point. Just have to look at your head before you order plugs.
