Post by fish88top on Apr 28, 2012 14:39:46 GMT -5
Does anyone have a tune or just a VE table from a 5.0. The base tune i got with my megasquirt 2 will not work. I can get the car to start (very hard) but it will not idle. It surges real bad then shuts off. Does it at all temps. The afr gauge reads lean but it smells rich. Any ideas would help. Thanx.
Post by Stinger on Apr 28, 2012 22:40:31 GMT -5
What's your mods?
Post by fish88top on Apr 29, 2012 14:37:59 GMT -5
I have a 306 Holley Systemax 205 valve heads, stage 2 ported Systemax intake, 512/512 lift cam 264/270 duration at 114 degree lobe sep. 1.6 rockers. Its a 5 spd I went through the whole start up guide its all correct as far as I can tell it just will not run. Oh I have the AEM wideband too.
Post by Stinger on Apr 29, 2012 15:43:22 GMT -5
What MS2 is it (from who/where)?
Post by fish88top on Apr 29, 2012 16:29:14 GMT -5
DIY auto tune they said the base tune was for a fairly stock 5.0. I figured mine wasn't too radical It would atleast start and run. Also forgot I have 24lb injectors and equal length shorty headers H-pipe without cats. The MS2 I got was already assembled. The one thing I see when going through all of the settings in TS is that in the ignition settings I have a few that are highlighted red and it says that the ecm needs rebooted.
Post by Stinger on Apr 29, 2012 22:20:37 GMT -5
You'll need to ask DIY about the red cells/rebooting. I can send you a VE table you can try but it's ready for boost rather than only to 100kpa like your current table. I'd need to email it so let me know your info.
It will be only the ve table, you'll have to use the import feature in tunerstudio.
Post by fish88top on Apr 30, 2012 16:49:23 GMT -5
Thanks Stinger My email is cfisher619@hotmail.com. That will atleast get me pointed in the right direction I think. I tried to adjust the VE table to see if wants more or less fuel and it really doesnt respond either way. I didnt adjust much Im afraid of causing any damage. So your table might atleast get me closer. Thanks again
Post by Stinger on May 2, 2012 14:44:46 GMT -5
Email sent.
FYI, you can't really damage anything by adjusting the tune for cranking/startup/idle. Super lean or super rich won't hurt it under those parameters. In other words, don't be afraid to add or subtract 20-30% fuel in an attempt to find the sweet spot.
Post by fish88top on May 4, 2012 19:26:03 GMT -5
Got the email. Your VE table is WAY lower than the one i got from DIY in the idle areas. Ill try it out Sat. and see what happens. Thanks again. Im sure I'll have more questions. I'm a total rookie with efi.
Post by fish88top on May 4, 2012 19:28:18 GMT -5
As far as the red highlighted areas (if comes up again) is just saying that if you change those settings you need to reboot the MS2 for it to take effect. It doesnt mean that it needs a reboot because of a problem.
