Post by crisart on Apr 29, 2012 23:03:12 GMT -5
lc-1 doesnt match the ms2 on tuner studios i did the recalibrationg and it seem to be giving me better reading on the laptop doesnt match the guage at all is there somtimg i can do or has anyone had this happen to them
Post by Stinger on Apr 29, 2012 23:28:27 GMT -5
You need to configure Tunerstudio so it knows what wideband you are using.
Tools > Calibrate AFR Table and then select Innovate LC1 Default from the dropdown menu. If that doesn't give you the correct reading, try the other two Innovate ones. If neither of those work, you need to figure out what your LC1 output is configured to and use "Custom Linear WB" and enter the voltage = afr settings.
svslow
Post by svslow on Apr 30, 2012 7:03:48 GMT -5
Also need to make sure that both LC1 outputs are programmed to output wideband readings. When I got mine, one was set to output like a wideband and the other a narrowband.
Post by crisart on May 2, 2012 23:50:21 GMT -5
well i got in the car and double checked everything and it seems the tuner studios says 14.7 and the guage says 10. i dont know if ts is correct it seems to be running fine but the guage says 10, or sometimes 7. cant figure it out
Post by Stinger on May 3, 2012 2:30:24 GMT -5
Did you do anything we said above? If they read different readings, it's not correct. The gauge is always right so your TS settings are wrong, period.
Post by crisart on May 3, 2012 22:44:26 GMT -5
Yes I did the go to tools afr lc1 default but how do I know if T/S is using that setting I also move the guage to a better ground and it worked at idle but after a while they where off again
Post by Stinger on May 3, 2012 23:21:04 GMT -5
If you set TS to default and click "write to controller" it uses default.
As I stated above, if default doesn't work, try the other Innovate options in that list. If those don't work, you need to use the software that came with your LC1 to program it's output to 0v = 10:1, 5v = 20:1 and then plug the same info into TS.
