yezzir
Boosting 10 psi
Post by yezzir on May 17, 2012 13:14:31 GMT -5
What's the best way to go go about verifying that base timing is 10 degrees with MS2 configured with EDIS? I used the tooth count instruction as written in the megasquirt manual, but wondering If I still need to verify command timing with a light? Also, I read with EDIS, the standard timing lights won't be accurate... Is that correct?
Post by khantyranitar on May 18, 2012 11:35:48 GMT -5
Assuming your trigger wheel and sensor are properly set, the EDIS (or DIS) are locked in at 10 degrees base timing. Standard timing lights should be correct. If the Megasquirt knows you have 10 degrees base, then the total commanded timing should be in actual degrees.
