Post by Stinger on Jun 30, 2010 23:11:05 GMT -5
Well, I had good and bad at the dyno. Made 14 pulls in almost 2 hours. Power was 20-30hp lower than I was expecting. On a positive note it makes right at 300rwhp at stock boost (15psi). Had some odd trends though were power jumped around quite a bit without changing anything. Boost pressure was inconsistent which is the most likely cause of that. Max HP of the day was made at 21psi. Unfortunately I hurt the engine after that run and power dropped off at higher boost. I drove it home though so it wasn't catastrophic. I'll post more info when they email me the dyno graphs and I verify the engine damage is what I think it is.
Post by oneowner88lx on Jul 2, 2010 22:12:46 GMT -5
Hopefully damage is not bad. Looking forward to seeing those graphs.
dizzle
Post by dizzle on Jul 8, 2010 18:34:25 GMT -5
I cant wait untill my car runs half that good. Heck or even at all at this point!
Post by oneowner88lx on Jul 12, 2010 8:42:09 GMT -5
Any updates?
Post by Stinger on Jul 12, 2010 13:34:11 GMT -5
No, not really. I haven't touched it since I drove it back from the dyno. I know what happened and what I'll do about it, just been taking a little break from working on it.
A rod bearing started knocking after the dyno session. I'm going to do a couple tests to verify before I yank the engine but I'm 100% sure it's rod knock. I think it was failing on at least the last 3 dyno pulls. The question I don't have an answer to is WHY it started knocking. I won't know that until I tear it apart. It was either from detonation early in the tuning process when I had boost control issues (30+psi on pump gas) and it slowly deteriorated from then or it was from when the cam seized up and took out the turbo, sending a bunch of aluminum into the oil in the process. This could have damaged all of the rod/main bearings and it was only a matter of time before they failed.
Once I get around to pulling the engine, I'll replace it with a "built" shortblock with Crower rods and such. I've got the built engine already (sitting in the dragster chassis), just need to put some new gaskets/seals in it since it's been sitting for a few years. Then I'll paint it and drop it in.
Post by oneowner88lx on Jul 12, 2010 21:24:47 GMT -5
Sorry to hear about that. Glad you stopped running it before something really bad happened. Now that the car is getting more sorted out the next block should last a good long time.
Post by Stinger on Jul 12, 2010 23:16:12 GMT -5
That is the hope. I also hope that the bearings are why it seemed to be down 20-40hp from where it should be and was also inconsistent from pull to pull.
Post by oneowner88lx on Jul 13, 2010 18:39:34 GMT -5
Should be interesting to see what the bearings look like once its apart.
Post by bobbarker on Aug 16, 2010 17:04:21 GMT -5
When you gonna get this thing back together?
Post by Stinger on Aug 16, 2010 22:48:02 GMT -5
Good question. As soon as sales slow down so I have time to mess with it. This doesn't mean I want you guys to stop buying things lol!
Post by bobbarker on Aug 22, 2010 15:17:02 GMT -5
Ha!
Post by Stinger on Aug 22, 2010 22:55:49 GMT -5
FYI, the "new" SVO engine has been pulled from the Dragster and once I get some bolts for the engine stand, I'll mount it to the stand and inspect the bearings and put some new gaskets and such on it and then it should be ready to go in (after I swap all the parts off the current SVO engine and onto this new one).
Post by blueovalfan on Aug 22, 2010 23:36:06 GMT -5
hell yah lets c some 300ft burnouts and lets see it peg a 30psi boost gauge ohh and then lets c some vettes get spanked ohh and lots of camaros yeah and some hondas, maybe even a challenger or 2
Post by Stinger on Sept 3, 2010 12:08:08 GMT -5
Well, hit another snag. This is the supposedly "good" engine that I bought years ago and hadn't ever ran (other than hearing it run before buying it): Pulled apart a 2.3T today and found this: All: Front Main: 2nd Main: Center: 4th: Rear Main: Center Crank Journal: Other Journals: #2 & #3 Rod Bearings:
Post by FRANK/TurboTempo on Sept 4, 2010 10:27:06 GMT -5
oil starvation, but the cause can be of many things . but a nice rebuild will help with the power.
