Post by denz on Mar 27, 2009 6:34:59 GMT -5
will my la3 and vam work with out the turbo? so i can wire them in and run to make sure it will work before i put my turbo on.
denz
Post by Strangeleak on Mar 27, 2009 9:09:27 GMT -5
Good questions, I too am interested in the answer. I'll be doing a swap soon (within the next year or so, lol). That would save a lot of stress cause mine is a daily driver and I will only have a weekend to do the whole swap.
Post by Stinger on Mar 27, 2009 12:44:37 GMT -5
Yes, it will work. It is no different than when you are cruising around out of boost. I actually ran my old 91LX this way after I blew the turbo and needed to drive it until the new turbo arrived.
Post by Strangeleak on Mar 27, 2009 14:52:07 GMT -5
Is it any more or less efficient than the stock computer and MAF as far as gas mileage is concerned? Or does it change the timing?
Post by denz on Mar 27, 2009 21:31:10 GMT -5
strangeleak that also i a good question, does it change, more or less power better or worse fuel?
Post by Stinger on Mar 29, 2009 17:30:55 GMT -5
It is a bit less efficient because it is an older ecu and not being used for it's intended purpose and uses a vam rather than mass air meter.
Post by Strangeleak on Apr 14, 2009 11:49:11 GMT -5
Another question came to mind. Is it necessary to use the brown top injectors with the Turbo ECU and VAM? Or can I use my factory one's until the swap?
Post by Stinger on Apr 15, 2009 12:15:40 GMT -5
You must use the proper injectors for the ecu.
