PiMP Engine Management Plug & Play Standalone ECU
Jan 10, 2013 23:53:29 GMT -5
turbotoys22 likes this
Post by Stinger on Jan 10, 2013 23:53:29 GMT -5
Stinger Performance PiMP Standalone Engine Management (2.3, 2.3T, 5.0, 4.6)
The Stinger Performance Plug-in Microsquirt Powered (PiMP) engine control unit is the most user-friendly and capable plug and play option available for Ford EEC-IV equipped vehicles. Plug and play means you remove the stock ecu, plug in the PiMP, run a vacuum/boost line from the PIMP to the engine, follow a few basic setup steps, plug in a wideband o2 meter, and it's ready to start up and begin tuning. It also allows you to remove the factory air meter (VAM on 2.3T cars, MAF on V8 cars) and run a filter directly off of your turbo or cold air tube.
Not only does it allow you to remove the factory air meter (which is a huge restriction on 2.3T powered vehicles) but it also features VE Live which is an auto tuning capability build into the tuning software. This powerful feature will tune the engine on it's own while you do nothing but drive around under varying conditions. This allows the end user to tune the idle and cruising portion of the fuel map to "better than stock" often in less than 30 minutes. Additionally, the PiMP comes with a base tune featuring dyno proven and safe timing maps that can be ran as provided or fine tuned to your particular setup as you see fit. The PiMP also allows for any injector size and type readily available for your application. When upgrading injectors, your new tune for larger injectors is only a few keystrokes away. The rev limit can be changed in seconds and the 2-step launch control feature (for building boost on the line when drag racing) can be configured to any trigger rpm and launch rpm you see fit. An advanced feature known as flat-shift is popular in many forms of racing, the intent of which is to hold boost between shifts to eliminate lag after shifting. It can also be configured to any rpm and timing retard value to tailor it to your car and driving style. Additionally, the PiMP can trigger two stages of Nitrous or Meth/Water Injection as well as switch to different fuel, timing, and target AFR tables when these systems are activated. Table switching can also be triggered via a toggle switch or the factory premium fuel switch so you can have "Race" and "Cruise" tunes or any other combination of tunes you may desire "on the fly". All of these features are configured to use the factory wiring harness and sensors for activation, though aftermarket switches can be used for Launch Control/Flat Shift activation if desired.
Based on MegaSquirt technology, the PiMP is designed to run the ignition system stock to your vehicle by default. Many different Ford ignition systems are supported including TFI, DIS, EDIS, CDI (MSD style ignition boxes), and via the Internal Expansion Port, Individual Coil Packs with a Crank Trigger. For non-stock ignition systems, additional wiring modifications or additions may be required.
The P.I.M.P. is a joint venture between Stinger Performance and Wes K.
Wes has been a member of the Turboford community since 2004, and actively involved in the Megasquirt project since 2004. Wes has had real input into the development of MS2 Extra and MS3 firmware. In addition to the DIY/Megasquirt type projects, Wes has worked as an engineer in the motorsports industry for several years, including experience with many high-end motorsports ECU's. This ecu began as a personal project of his and as time went on he decided it would be most beneficial to have more boards made and offer them to the masses. At that point he contacted Stinger Performance and we began working out the details and coming up with a final product for production. With two engineers involved with the design and support of the PiMP, the attention to detail and quality is second to none.
The PiMP can be connected to laptop via USB or Serial port. We do advise you use the Serial cable if your laptop supports it. If you only have USB capability, you can purchase the required USB to Serial adapter HERE.
The PiMP was designed to work in any EEC-IV (OBD-1) Ford vehicle (~83-95), though it hasn't been testing in all possible applications. The tested and verified working applications are listed below.
All of the software and documentation needed to get you up and running comes on a 1GB USB Flash Drive. That way you don't need wireless internet to access these items. A 20 page startup guide covers every detail to get you up and running including PiMP installation, software setup, hardware configuration, and USB adapter driver installation (when required). The PiMP section of our Tech Forum is available to cover any questions you may have that aren't covered in the startup guide.
Note that all PiMP's are built exactly the same. The end user can configure the PiMP to work with the vehicles/engines listed below without needing to send the unit back to upgrading. This means you can use it in a 2.3 powered car. Then if you purchase a 5.0 or something else down the road, you can re-configure it to work in the V8 car without issue. This is a feature that is exclusive to the PiMP and not available elsewhere.
Also note that the PiMP comes with all features built-in. No need to pay for each feature or send it back to upgrade to additional features (unless they are advanced features that are not listed below). Also note that you can get $70 worth of software for only $30 with this ECU which you will not find anywhere else.
Tested Direct Plug & Play Into:
-87-93 2.3 Mustang
-87-94 5.0 Mustang
-83-86 2.3 Turbo Mustang (SVO, Turbo GT)
-83-88 2.3 Turbo Thunderbird Turbo Coupe
-85-89 2.3 Turbo Merkur XR4Ti
-87-95 2.3 Ranger
Also Capable of Running:
-95-96 4.6 Mustang
-89-97 Probe
-89-95 Taurus
-virtually any other EEC-IV (OBD-1) Ford vehicle
Features/Capabilities:
-VE Analyze Live "Auto Tune" (More Info)
-Ignition Spark Control
-Fuel Control
-Idle Control
-Table Switching
-Electronic Boost Control
-Rev Limiter Control
-Launch Control (2-Step)
-Flat-Shift (Maintains boost between shifts)
-Two Stage Cooling Fan Control
-Nitrous Control
-Supports Low Impedance 4 Cyl Injector Control
-Supports High Impedance Injector Control
-4 Bar (44psi) Internal Map Sensor
-Full Datalogging
-DB-25 Internal Expansion Connector
-and many other features and capabilities...
Includes:
-PiMP ECU
-1GB USB Flash Drive (containing all required software, startup instructions, base tune, etc)
-Licensed TunerStudioMS Tuning Software ($69.95 value) (More Info)
-MegaLogViewer Datalogging Software (More Info)
-Serial Communication Cable (Serial RS-232)
-Silicone Vacuum Hose with zip ties
-PiMP Engine Management Sticker
-Startup Guide
-Software Setup Guide
-Online Technical Support Forum
-Online Tuning Guides
-Online Tutorials
Requires:
-Windows 95 or Newer Laptop
-Wideband o2 Sensor Controller with Analog Output
PiMP Engine Management System v1.2 (Made In The USA) - IN STOCK!!!
View Price & Purchase Here: www.stinger-performance.com/universalparts.html
-87-93 2.3 Mustang
-87-94 5.0 Mustang
-87-95 2.3 Ranger
-95-96 4.6 Mustang
-89-97 Probe
-89-95 Taurus
-Fuel Control
-Idle Control
-Table Switching
-Nitrous Control
-Full Datalogging
Includes:
-PiMP ECU
-Startup Guide
-Online Tutorials
Requires:
