Rings
Apr 21, 2009 17:59:10 GMT -5
Post by 90turboswapper on Apr 21, 2009 17:59:10 GMT -5
wanted to know what to set the ring gap to any help i was thinking area of 26
Rings
May 4, 2009 12:20:53 GMT -5
Post by Matt Culpepper 2300gearjammer on May 4, 2009 12:20:53 GMT -5
uuuh first lets lay out a few more details.
Assuming you are talking about a piston ring gap, are they stock replacement rings or aftermarket?
The factory ring gap is: Top ring- .010-.020 2nd ring- .010-.020
if you are doing this yourself, (you have a powered ring gap grinder and you really want to make it correct), you can order an oversize ring bigger than your cylinder. This way you can cut the gap to whatever you want which is tight to spec. I just crammed my in and went with it. Ring gap was about .013
Rings
May 5, 2009 0:51:50 GMT -5
Post by Stinger on May 5, 2009 0:51:50 GMT -5
Typically you run a bit more on the upper ring than the second because it will be subjected to more heat and therefore expand more.
