Post by spoolin23t on Aug 8, 2013 17:19:53 GMT -5
Main ground I put too intake manifold, start up and engine on wire, only thing is gauges, better off getting aftermarket for oil pressure, and coolant temp and aftermarket tach
Post by Stinger on Aug 8, 2013 17:38:23 GMT -5
Why is it better to get aftermarket oil, coolant, and tach?
Post by spoolin23t on Aug 9, 2013 17:14:44 GMT -5
There isn't a closed circuit anymore those green clips have the wiring for the factory gauges( by where the ecu is). So I'm going to run aftermarket gauges.
Post by spoolin23t on Aug 9, 2013 17:16:50 GMT -5
Why is it better to get aftermarket oil, coolant, and tach? If you have tested this harness, please give me some insite on how you wired the gauges or pictures . Rite now I have to drive around with my laptop because they don't work.
don33
Post by don33 on Aug 15, 2013 16:06:35 GMT -5
If there is no provision for the gauges on the new harness, cant you just run wire from your sensors to your factory gauges ? splice into the original wires that run to them ?
