Post by 93notchtc on Apr 29, 2009 13:39:16 GMT -5
Hello guys I have just got a 93 mustsng with s 88 tc engine in it. I dont know to much about it. The car is running poorly when I get to about 10lbs of boost it breaks up really bad. I pulled the i/c off and the hose between the turbo and the i/c has a rip in it. can any one tell me were to order new hoses. I put a cheap hose on it but it blow that one out at about 20lbs of boost. Ran great till it poped the hose again. Thanks for the help Josh
Post by Stinger on Apr 29, 2009 23:27:05 GMT -5
Forced4.com sells replacement hoses.
Post by 93notchtc on Apr 30, 2009 6:54:12 GMT -5
Thanks for the help. I got a few more ?'s could you tell me about what this car will run in the 1/4. This is what I was told when bought the car. 88 tc engine 255lph pump afpr (@ 40 with vac line hooked up 50 when I pull line off) brown top injectors 3" exhaust. What looks to be a homemade boost controller. A greddy type S bov. It has a 8.8 rearend with 3.73 gears and a spool. It has drag spring in the rear but I don't remember the brand. It has m/t dr about 10" wide on the back and skinny tires on the front 4" wide rims are weld drag lites I belive. When it was running good if I heat up the tire it would hook and take off. This is me 1st turbo mustang. I have had a few 5.0 cars. This one seems to pull pretty good. I'm getting 18-20lbs of boost by 3500rpms
Post by 93notchtc on Apr 30, 2009 6:57:10 GMT -5
Thanks for the help. I also sent you a message on eBay
Post by Stinger on Apr 30, 2009 12:22:15 GMT -5
It's hard to say what it will run. Assuming everything is proper (tune, driving technique, engine condition, etc.) I'd say somewhere in the low to mid 13's.
