Post by 93notchtc on May 6, 2009 12:35:52 GMT -5
I would like to run low 12's with my new mustang notch tc. this is what has been done to the car before I got it. greddy bov 255lph pump and afpr brown tops 18psi of boost. 3.73 gears and a spool big radiator 3.5x15 welds in the front 8x18 in rear with mt dr battery is in the drunk. Eibach Drag-Launch Springs in rear with 4cyl springs in front It has a t 5 that grinds going in to 4th but that will be changed. the car has full int and I weigh 280lbs can some one give me a list Of parts to get me in the low 12's high 11's this car will be a street/strip car. thanks for the help
Post by Stinger on May 6, 2009 16:21:54 GMT -5
3" Exhaust with straight through muffler Cone Filter Manual boost controller Adjustable Fuel Pressure Regulator Remove Excess Weight in car Front Mount Intercooler kit Turn up boost to 23psi or so (if you can get away with it on pump gas and you have a T3 turbo). Boport cam Get an MSD box with a 2 step for launch control. Learn to drive it Run 12's
