Post by ranger84 on May 9, 2009 18:56:34 GMT -5
Hi there new to the site just wondering if some one can help me out with my project i have 2 turbo coupe's one is an 87 and one an 88 complete the 87 has a t3/t4 turbo and aftermarket fuel pressure regulator and a front mount Svo Int cooler and a t5 with a la3 Computer Dynoed at 300Rwhp and the other car is stock i want to install the 2.3t into my Ford Ranger 1984 it was a carbureratord 2.3 before .I guess what i need to know is about the wiring harness from the TC what i need and don't need to wire it up to run .. Any help would be great
Post by Stinger on May 9, 2009 20:18:31 GMT -5
Why not drive the 87? It would be much safer at 300hp than your Ranger.
Regardless, you'll need to upgrade the fuel system to EFI specs (new pump, return line, etc.) as well.
As for wiring, I'd find an 87-90 2.3 Mustang harness (or 83-86 Turbo coupe) and start with that. It is much simpler than the 87-88 Harness and would be much easier to hook up. Once you get one of those harnesses, just compare the wiring diagrams for the Ranger and car the harness came out of and it should be pretty simple.
Post by ranger84 on May 10, 2009 19:10:50 GMT -5
hey thanks for the info As for the 87 Tc it had been vandalized its in bad shape and the 88 is rusty so thats why i would like to the swap also the truck has a 9'' ford and was set up for drag racing also had a 302 .. The ranger Is a Short box and is lowered 4'' well thanks again for the info How do you upload pictures on the profile ??
Post by Stinger on May 10, 2009 22:25:41 GMT -5
You have to use a file hosting site to upload pics (photobucket, mediafire, etc.).
