Post by Stinger on Nov 26, 2013 14:46:36 GMT -5
A manual boost controller will let you raise the boost with that wastegate spring, just like you can with a stock wastegate (that also has an 8-9psi spring inside).
Venting the valve cover isn't in the same universe as a full catch can setup.
guss
Post by guss on Jun 27, 2024 8:07:13 GMT -5
I'm interested in this thread we have a stock 84 2.3 gt350 turbo car.we have some upgrades in the wings .We have two big 3in vams have to test them to verify. Have a set of brown top injectors need to have flow tested. We also have a svo intercooler but might just sell and go with a front mount. But that would be last. We have our stock ecm n an 86 t bird turbo ecm. But looking for a pe or la Ecm. Getting back to pcv. Have way to much pressure in engine at its stock set up. If I pull oil fill cap it will stall out.? Oil out dipstick once in awhile. Have oil in intake all way to vam. Need to do something to pcv system asap.
Post by Stinger on Jun 27, 2024 12:41:50 GMT -5
