Post by 93turbopony on Jun 14, 2014 18:53:14 GMT -5
finally got to make some passes,
1/8th mi 9.0531 60ft-2.1601 mph 82.57
running on junk street tires, spinning badly. jist of mods stock bottomend stock head, bo 1.9 cam PIMP 50 trim 20psi 60lb injectors stinger header 3' exhaust npr intercooler 40 bob intakes.
Post by Stinger on Jun 14, 2014 20:11:04 GMT -5
Good to see you out on the track. That converts to about a 14.1 @ 102 in the 1/4. Have you done a leakdown test on this engine? What rpm were you shifting at?
Post by 93turbopony on Jun 14, 2014 20:39:28 GMT -5
i havent leak tested it but i know the valves leak bad, and have cracked seates. I have a frsh head that id like to get worked over. I was shifting at a little over 6k, watever that stock limiter is.
Post by Stinger on Jun 15, 2014 0:20:19 GMT -5
Ah, that's what I was suspecting. It's probably robbing you of 50hp or more.
Post by 93turbopony on Jun 15, 2014 21:18:36 GMT -5
yah i was afraid of that, seems like other guys are going faster with less boost. When I get my new head back from the machine shop, ill do a update maybe ill have some tires aswell.
