Post by nosbaby on Jul 24, 2014 12:11:33 GMT -5
I've got my microsquirt all wired up. Most things seem to be working. I'm using tuner studio. 2.3 turbo with a TFI and I'm supposed to change the spark A to the wled...I can't for the life of me figure out where to do it. I'm going to blame it on sleep deprivation....but I'm probably just an idiot
Post by Stinger on Jul 24, 2014 13:21:56 GMT -5
Is it a cased microsquirt or a pnp or did you buy a micro module and build your own?
Post by nosbaby on Jul 24, 2014 14:13:34 GMT -5
This is a cased microsquirt.
Post by nosbaby on Jul 24, 2014 14:18:05 GMT -5
This is the way I went about hooking it up.... www.msextra.com/doc/ms2extra/MS2-Extra_TFI.htmI followed the microsquirt instructions, but my menus in tuner studio don't look like these. Missing the option to change my spark A output.
Post by wesk on Jul 24, 2014 15:05:12 GMT -5
What firmware? With current firmware it is under ignition options. You must have your project defined as a cased microsquirt in project properties.
What ignition input did you use (opto or VR1 in)? I have used cased microsquirt, newer firmware, and "wled" spark.
Post by nosbaby on Jul 24, 2014 15:16:10 GMT -5
My firmware is V3.77 Embedded code by B&G. I didn't see any place to specify it was a cased microsquirt. I just used the detect option for the firmware. I used VR1. Pin 1 and pin 33 with a 1k resistor between them. Pin 33 to pip....pin 17 to spout.
Post by nosbaby on Jul 24, 2014 16:16:35 GMT -5
Ok Wess....thank you. You got me on the right track. Changed the firmware version to 3.3.2 ....now its all there and it finally shows a tach input. Yay me! One step closer. This thing is supposed to race first thing in September!
Post by wesk on Jul 25, 2014 8:56:21 GMT -5
Post by nosbaby on Jul 25, 2014 9:01:48 GMT -5
Sorry Wes....yes 1 and 17. I wrote that incorrectly. Car officially runs now. Plenty of tuning left to go...but running lowers some of my stress level
