Post by Stinger on Jul 31, 2014 1:39:10 GMT -5
SVO Bi-Wing Supports Simple to install upper bi-wing supports for SVO Mustangs. Fully adjustable, easy to install, great looking, and functional. The upper wing is prone to sagging so you can use these to lift your sagging wing back up, or to prevent your non-sagging wing from sagging in the future. Top post fits into existing holes in upper wing. Simply test fit, mark the glass with tape, stick 3M double sided tape to bottom and stick them in place. Now simply adjust the length of the threaded base to raise your wing to the correct level and then tighten the jam nut to lock it in place. Made from 6061 Aluminum with a zinc coated steel base. No drilling or modifications required. If you prefer a more subtle look, simply spray them with a flat or satin black trim paint to match the upper and lower wing color. Price: $ 55.00 Shipped
Post by Markku Kesala on Aug 18, 2016 12:36:34 GMT -5
Hi there,
I am interested in purchasing this bi-wing support for my SVO. How can I order it? I don't find it listed anywhere on your website?
Post by Stinger on Aug 18, 2016 13:23:41 GMT -5
Post by Markku Kesala on Aug 18, 2016 16:16:52 GMT -5
Thanks! Somehow I missed it when I scrolled down the page before. I just order it.
Post by Kraig Ogdon on Jan 27, 2020 16:24:22 GMT -5
I will be ordering these for my 84 SVO, and I also hace a different car with a upper wing, is it possible to get the measurements for these Upper wing SVO supports ?
Post by Stinger on Jan 27, 2020 20:07:50 GMT -5
3.5" long threaded all the way in, probably goes out to 4.25" or so. 3/8" OD.
