Post by Stinger on Nov 19, 2014 23:25:30 GMT -5
Head Flow Data from BoPort Racing Heads: All heads were bone stock other than cleaning carbon off the ports. Factory valve job, same valve used for all tests. This is an intake flow comparison tested at 28" water on the flow bench. A 1/2" clay radius was used on the port entrance. Cylinder number 3 port was used on all tests but the ranger round port, in which cylinder #4 was used. Back to back testing was done on the same day. Lift | N/A D Port | Turbo D Port | N/A Oval Port | N/A Round Port | Late Dual Plug | Early Dual Plug | Esslinger D Port | Ported Esslinger D Port | Ported Turbo D Stage 4 | Esslinger ARCA | Volvo | Esslinger XT | Chinese Iron |
| .050" | 27.55 | 27.8 | 28.6 | 31.0 | 30.0 | 27.3 | 28.1 | 29.6 | 33.2 | 33.7 | 42.3 |
| .100" | 48.9 | 54.5 | 55.9 | 59.0 | 58.0 | 54.9 | 51.4 | 61.3 | 65.6 | 61.3 | 85.1 |
| .150" | 61.8 | 75.4 | 78.9 | 77.7 | 86.7 | 78.3 | 76.7 | 94.5 | 106.5 | 91.6 | 123.9 |
| .200" | 75.2 | 100.6 | 100.3 | 101.6 | 110.7 | 96.1 | 105.5 | 123.6 | 138.8 | 122.0 | 164.1 |
| .250" | 88.0 | 120.7 | 122.3 | 122.0 | 130.3 | 109.4 | 132.3 | 147.2 | 169.3 | 149.8 | 198.5 |
| .300" | 101.6 | 132.3 | 136.8 | 135.5 | 143.3 | 120.4 | 156.3 | 169.9 | 196.5 | 175.8 | 219.2 |
| .350" | 116.5 | 140.1 | 146.6 | 142.7 | 153.1 | 128.4 | 177.7 | 189.4 | 218.6 | 198.5 | 226.4 |
| .400" | 131.0 | 144.0 | 150.5 | 145.3 | 158.9 | 132.3 | 190.7 | 207.6 | 234.8 | 218.6 | 229.6 |
| .450" | 144.0 | 149.2 | 153.1 | 145.9 | 164.1 | 134.9 | 199.8 | 220.5 | 247.1 | 236.1 | 231.6 |
| .500" | 151.8 | 154.4 | 156.9 | 149.2 | 166.8 | 136.8 | 205.6 | 231.6 | 250.4 | 252.3 | 234.1 |
| .550" | 158.2 | 159.5 | 156.3 | 150.5 | 168.8 | 138.8 | 210.1 | 236.1 |
| 265.9 | 235.4 |
| .600" | 163.4 | 160.8 | 156.3 | 151.8 | 170.2 | 140.1 | 214.7 | 237.4 |
| 275.0 | 235.4 |
| .650" |
| 206.9 |
| 283.1 |
| .700" |
| 207.6 |
| 290.2 |
Post by Strangeleak on Nov 20, 2014 9:13:06 GMT -5
Awesome data!
How much room does a Volvo head have to port? Can it take larger valves? That would be interesting to see.
Post by Stinger on Nov 20, 2014 14:20:51 GMT -5
It can be improved with porting, and can have slightly larger valves installed. Getting performance cams for it is an issue though.
mavereq
Microsquirt Premium
Post by mavereq on Jul 30, 2016 23:55:06 GMT -5
I've been reading up on the ranger round port. I read that they're capable of great flow but they're hard to port without hitting water. I have one and have been toying with the idea of porting it myself. Do you have any experience with them?
Post by Stinger on Jul 31, 2016 1:47:03 GMT -5
I don't have any porting experience with them.
mavereq
Microsquirt Premium
Post by mavereq on Feb 22, 2017 20:47:16 GMT -5
Curious about the low numbers on the n/a d-port. Are the runners a lot smaller, or does the combustion chamber shroud the valves too much?
Post by Stinger on Feb 22, 2017 22:50:48 GMT -5
I don't know for sure but that's the likely cause.
Post by don33rbc on Jun 30, 2020 23:58:00 GMT -5
Wish he would have flowed an Esslinger SVO head.
