Post by Stinger on Sept 27, 2009 21:24:06 GMT -5
Loosen the 6 bolts on the compressor housing and rotate it.
Post by 93stangnow23t on Sept 27, 2009 21:53:50 GMT -5
I Don't have to worry about Seals?
Post by Stinger on Sept 27, 2009 23:49:03 GMT -5
Not typically. Aftermarket turbos use a machined surface to seal. Stock T3's sometimes have a thin paper gasket that can be replaced with a piece of cereal box cut to the right shape if the stock gasket rips.
Post by 93stangnow23t on Sept 28, 2009 7:33:54 GMT -5
Does that mean that there is one in that spot and to not be vigorous with it so I don't mess it up?
Post by Stinger on Sept 28, 2009 12:38:14 GMT -5
Depends if it has been apart before...odds are there is one there though.
Post by denz on Sept 28, 2009 12:54:13 GMT -5
on back side of turbo compressor housing is some bolts going around the rim of housing, loosen bolts and turn housing mine was hard to turn use pen oil (wd40/break away) soak it first. be careful there is a gasket.
Post by 93stangnow23t on Sept 28, 2009 16:24:26 GMT -5
Question I bought an intake gasket kit and i have some stuff I don't know were it goes. First three I do know were they go. These ones I have no clue
Post by denz on Sept 28, 2009 17:04:57 GMT -5
thermo house or turbo input lower right, EGR lower left, inline intake manifold between top and bottom.
Post by 93stangnow23t on Sept 28, 2009 17:29:43 GMT -5
Its not the EGR Looks alot diff in the motor.
Post by denz on Sept 28, 2009 20:09:21 GMT -5
maybe not your egr but this gasket kit fits many years that is why you have extra gaskets. what year is your motor.
Post by 93stangnow23t on Sept 28, 2009 20:59:49 GMT -5
86 it looks like it goes to the TPS
Post by Strangeleak on Sept 29, 2009 6:33:41 GMT -5
Actually, it goes to the Idle Air Control Valve. Notice the resemblance, this valve isn't for a 2.3, but it's similar.
Post by 93stangnow23t on Sept 29, 2009 15:56:32 GMT -5
That's what I was looking at but couldn't recall the name of it.
Post by denz on Sept 29, 2009 19:43:28 GMT -5
well i was close, hope helped a little
Post by 93stangnow23t on Oct 7, 2009 18:03:58 GMT -5
I don't understand this why cant I use a 87-90 wiring harness? I mean I'm going to a distributor system I would expect that a 87-90 harness would make it easier to change out. Only reason I ask is because someone brought it up on another site.
