Post by SLO FRD on Jul 2, 2009 16:06:09 GMT -5
Chassis Type: 93 Convertable
Short Block Mods/Compression Ratio/Displacement: Stock Just completely rebuilt. again!
Head/Port Work/Valve Size: Stock Ported head
Cam Specs/Degrees Adv-Ret: Stock/ - 6* Intake/Throttle Body: Gutted Upper, (Ported lower and sn95 TB coming soon.)
Intercooler: Custom FMIC
Nitrous System/Shot Size: Wet 50 Shot (Never used)
Exhaust Manifold/Header Type: Stinger Header
Turbo: Stock SVO T3 Wastegate: External 38mm
Exhaust Size/Type: 2.5 DP, Connected to Stinger 3" DP back to 2.5 Mangnaflows to 3" Basani Tail pipes Engine Management: La3 Injectors: Stock brown top Air/Fuel Ratio, Total Timing, Boost: AFR??/ 22*/ 13lbs Fuel Octane/Brand/Leaded or Unleaded: 91 Octane Unleaded HP@RPM: 156@ 6250 TQ@RPM: 189@ 3500 Flex plate/Flywheel: Stock Convertor/Clutch: Stock Clutch Transmission: 88TC Rear/Ratio/Tire Type/Tire Size: 285/45/17 BFG G FORCE T/A Race Weight Without Driver: Its a Vert 3000+ ET/MPH: nvr ran.
Post by SLO FRD on Jul 2, 2009 16:32:39 GMT -5
Here are the pictures! These pictures are a couple months old.. The engine bay is allot cleaner now.
Post by Stinger on Jul 3, 2009 1:01:44 GMT -5
Car looks nice, underhood looks good (except for the mismatched/dirty couplers and clamps) but those HP numbers are WAY down from what they should be. Why is the cam retarded so far? Are you sure the exhaust valves are sealing?
Stock SVO's dyno more than that (normally 165-170hp and 240-280 tq).
Post by SLO FRD on Jul 3, 2009 9:59:08 GMT -5
Forgot to mention those numbers were on a motor with 58miles with an ihi, front mount, fuscia colored injectors, adj camgear,gutted top intake, full exhaust, and 13lbs of boost.. so i dont think it was too bad.
Post by SLO FRD on Jul 3, 2009 10:07:43 GMT -5
As for the Mismatched/dirty couplers lol the intake side has been completely welded and the turbo side is next. Now that i got your header on it im gonna weld. and it has new springs, the heads been ported and polished and reseated, and was tested for leaks! and it was advanced 6*
