Post by bgpickle on Jul 17, 2009 16:41:43 GMT -5
i installed a 84 svo suspension in my sons 91 mustang, when i was done i noticed that the rear tires stuck out about 3/4 of an inch out more on both sides then it did with the stock one wheel peel rear. why is this so? i thought all fox rears were the same dim. should i install the rear disk brakes onto an 8.8? will this move the tires in, back where they belong?
Post by Stinger on Jul 17, 2009 21:03:08 GMT -5
SVO rears are 1.5" wider than any other Mustang rear before 94, that is why. They front suspension is wider than a regular mustang as well, particularly when used with the SVO k member.
TC's (which area also fox body cars) have a 3/4" wider rear as well...same as the 94+ Mustangs.
jinx44
Post by jinx44 on Jul 18, 2009 9:48:48 GMT -5
The rear axle housing is actually the same width, all the way up to '98. The difference is the outer part of the axle is longer for disc brakes.
Post by bgpickle on Jul 19, 2009 19:51:12 GMT -5
Can I install an 8.8 and swap the disc brakes over to that rear to get the wheel clearance? If what you say is correct even the 8.8 is the same width. Just the axles are wider. Can the brackets be modified to fit a standard axle from a 8.8 drum rear? i don't like how the tires fit in the wheel well!
Post by Stinger on Jul 19, 2009 22:34:08 GMT -5
You can flip the caliper brackets to move it in farther. I can't remember the details though. I'll see what I can dig up.
jinx44
Post by jinx44 on Jul 20, 2009 9:12:26 GMT -5
'83-'92 Ranger/Bronco II Left (driver) side axle (29-5/32") from a 4cyl or 3.0L V-6 with the 7.5" rear end, or '86-'97 Aerostar RIGHT side axles. You will need a pair of either axle. They will be 5 lug, and the same length as a stock fox body axle.
Then as stinger said, you can flip the brackets, or even modify them and mount them on the inside of the housing flange. If I recall, either way requires a little bit of modification in regards to the spacing.
Post by cjdavid on Aug 1, 2009 18:57:45 GMT -5
I just wonder, is there a problem with the wheels being 3/4 out on either side of the car? Clearance maybe? Can one use a different wheel to get it back in a bit further?
Post by Stinger on Aug 2, 2009 18:07:38 GMT -5
Using 2005+ Mustang wheels will put them back where they should be. They have more backspacing than the earlier Mustangs.
Post by cjdavid on Aug 7, 2009 16:31:46 GMT -5
SO IF ONE ROLLS THE FENDER LIP DOES THAT GIVE THE NECESSARY CLEARANCE? i HAVE THE ENTIRE DRIVE LINE OUT OF AN 88 TC THAT I PLAN ON PUTTING INTO AN 86 TRUNK CAR. I WANT TO KEEP THE 4 LUG (CALL ME CRAZY) JUST WONDERING WHERE THE CLEARANCE ISSUE IS, THE OUTSIDE , OR REAR?
Post by Stinger on Aug 7, 2009 18:08:33 GMT -5
SO IF ONE ROLLS THE FENDER LIP DOES THAT GIVE THE NECESSARY CLEARANCE? i HAVE THE ENTIRE DRIVE LINE OUT OF AN 88 TC THAT I PLAN ON PUTTING INTO AN 86 TRUNK CAR. I WANT TO KEEP THE 4 LUG (CALL ME CRAZY) JUST WONDERING WHERE THE CLEARANCE ISSUE IS, THE OUTSIDE , OR REAR? You don't have an SVO rear so the problem doesn't apply to your situation. The TC rear is 3/4" wider than a Mustang rear but that's not enough to cause a problem.
Post by reaper5lm on Aug 7, 2009 18:24:30 GMT -5
acjdavid, I have that set up 88tc REAR no issues I run a 275/60/15 . I just rolled the fenders for a little better clearance on the bumps, they would hit some times.
Post by merc460 on Aug 8, 2009 17:40:18 GMT -5
Here are some pics of my 88 with a 8.8 and Lincoln/ SVO rear axles and Factory ford 17 X 8 with 235 width tires.
Post by oneowner88lx on Aug 18, 2009 13:39:53 GMT -5
You don't have an SVO rear so the problem doesn't apply to your situation. The TC rear is 3/4" wider than a Mustang rear but that's not enough to cause a problem. Just to clarify the TC rear is 3/4" wider overall then the standard fox Mustang rear? Reason I ask is because I am putting an '88 TC rear into an '88 Mustang hatchback. Sounds like the wheels will only be 3/8" further out which shouldn't be noticeable.
Post by Stinger on Aug 18, 2009 13:48:44 GMT -5
Correct.
Post by oneowner88lx on Aug 25, 2009 17:46:46 GMT -5
Will the 7.5 axles and brakes off an '88 Mustang fit on an '88 TC rear? I would like to avoid the disc brake swap for the time being.
