Post by J Coyote on Feb 27, 2016 19:30:45 GMT -5
88 Merkur X
Revolution Automotive Tuned 2.3 Ford Turbo Pimp system Stage 3 Boport Head, Stage 3 Boport Cam, Adjustable Cam Gear 65mm TB, Gutted rotated intake Turbo Joe Custom Fuel Rail Adjustable fuel reg 80 lbs injectors, 255 walbro pump Holset Turbo, custom Centermount Header (from arcwerkz customs) FMIC, Stinger 38mm wastegate HKS Bov Msd 6al Msd Coil Stinger 3"Exhaust
-Transmission World Class T5, Husrt Short Shifter, Spec aluminum flywheel Spec 3+ clutch one piece driveshaft 8.8 solid rear w/373 posi
-Interior Bride racing Seat g force 5 point seatbelt harness Autometer gauges Aem wide band pioneer head unit 12'pioneer sub woofer 500 punch amp
-Suspension Omp upper n lower front strut bar Omp upper n lower rear strut bar Front Adjustable Coilover (500lbs) Rear springs (700lbs)
-Wheels n Tire's 10th anniversary sve mustang rims 17x9 Front 225 45 contisport 17x10 Rear 255 40 contisport
-Brake Front PBR calipers 12' front rotor Rear drums
Post by Stinger on Feb 28, 2016 14:11:28 GMT -5
Pretty slick looking ride. That combo should make a lot of power if you've got enough injector and fuel pump to crank it up.
Post by J Coyote on Feb 28, 2016 15:52:14 GMT -5
Thanks man,Thats what im hoping for dying to feel the results(after tuning)w/the pimp & 80lbs injection and go from there.Ill post better pics of everything when I get this thing going.
