Post by corymck89 on Aug 4, 2016 5:25:18 GMT -5
Ya i also did that and came up with .66 at idle car seems to make about 13.5~ ish volts
Post by Stinger on Aug 4, 2016 9:40:40 GMT -5
Use that number and see where your idle VE ends up. If it's way off from where it should be, we need to look at your injector part # to verify they are 83lb.
Post by corymck89 on Aug 5, 2016 11:25:47 GMT -5
Still seems off hasnt changed much
Post by Stinger on Aug 5, 2016 12:34:40 GMT -5
Where are your idle VE numbers after changing the dead time to .66 and re-tuning to 14.7 AFR at idle?
Post by corymck89 on Oct 6, 2016 18:31:26 GMT -5
I have my dead time set at 0.60 ( from the chart from holley at 13.6-14 volts 0.60 is between the two. Still no change even after retune.
I also tried turning off ego and accell enrichment. Still no difference
The only thing i havnt messed with is the timing table.
This issue it killing me! Im not sure what else i can do? And
Post by corymck89 on Oct 7, 2016 8:11:28 GMT -5
I believe i got issue fixed, on required fuel calculator i had 140cid and it was required fuel 10.0 and and i changed it to cc's (2301) and it changed required fuel to 4.4
Post by Stinger on Oct 7, 2016 9:08:55 GMT -5
Those two required fuel values are stock injector vs 83lb so that will certainly make a large difference. You should expect to have to re-tune your fuel/ve table if it was tuned with a required fuel of 10.0.
