Post by Stinger on Sept 19, 2009 23:47:54 GMT -5
Put it in the factory location for a small amount of time...one or two short pulls shouldn't overheat the sensor.
Post by sleepinsol on Sept 20, 2009 15:42:00 GMT -5
problem fixed. swapped out vams last night, and as it would turn out i had my bpv in backwards so it was leaking pressure instead of relieving it . anyway im going to run it on the other vam just to be sure it wasnt the problem as soon as the rain stops. but since it ran on 2 other cars before this one im certain it is ok. thank you for all of your help and insight!
DRD
Boosting 10 psi
Post by DRD on Oct 5, 2009 17:55:00 GMT -5
I had a problem a lot like yours. It ended up being the air filter. You checked the air filter right.
DRD
Boosting 10 psi
Post by DRD on Oct 5, 2009 17:57:27 GMT -5
oops! sorry i dident read the last two post
