Idea
Sept 14, 2009 14:49:14 GMT -5
Post by 93stangnow23t on Sept 14, 2009 14:49:14 GMT -5
well what i want to do is do something that doesnt involve rewiring mainly because i dont trust myself to do it and i dont think i have all the parts needed.
I'm probably going to get it rewired by Matt but my question is the coil do i replace it and i forget what it is called but the block that the power wire for the Distributor comes from i have anything else for ignition?
Sorry about this just really concerned my only car and all i can hear is my mom saying you cant do it which i want to prove her wrong BUT i dont want to screw my motor up or forget something and not be able to afford to put it back together.
The thing that would help the most is if someone came and helped me who did this before but no one lives close enough.
Idea
Sept 14, 2009 20:18:16 GMT -5
Post by Stinger on Sept 14, 2009 20:18:16 GMT -5
You have to rewire regardless of which engine you use so you're out of luck there.
You use whatever ignition components that go with your engine. Turbo engine = turbo ignition, your engine = your ignition.
Seems to me if you're worried about not being able to put it back together, it would be best to have a complete engine that you can put back in if something doesn't work out...rebuilding your engine makes that impossible.
There is a certain amount of knowledge that goes along with owning/driving a turbocharged car. You'll want to make sure you have that before diving in, otherwise you're asking for trouble.
Idea
Sept 14, 2009 21:00:15 GMT -5
Post by 93stangnow23t on Sept 14, 2009 21:00:15 GMT -5
what do i need ignition wise for the distributerd version?
Idea
Sept 15, 2009 11:42:58 GMT -5
Post by Stinger on Sept 15, 2009 11:42:58 GMT -5
Coil, distributor (with tfi module attached), plug wires.
Idea
Sept 15, 2009 15:37:10 GMT -5
Post by 93stangnow23t on Sept 15, 2009 15:37:10 GMT -5
Distributors attached to the motor so i have that wires i left on the motor so i have that Coil i also have so im in good shape?
Idea
Sept 17, 2009 19:38:28 GMT -5
Post by Stinger on Sept 17, 2009 19:38:28 GMT -5
It's all explained in the swap page. Sounds like you are "in good shape" as far as the parts you need. Still need to rewire and such.
Idea
Sept 18, 2009 23:10:15 GMT -5
Post by 93stangnow23t on Sept 18, 2009 23:10:15 GMT -5
yea that's guarantied
