Injector
Jul 6, 2017 7:38:55 GMT -5
via mobile
Post by 331mustang on Jul 6, 2017 7:38:55 GMT -5
I'm really interested in the pimpxs, but I heard you need a high impedance injector I have 42lb injectors they are the short fat green one. Can someone help
Post by Stinger on Jul 6, 2017 16:50:44 GMT -5
It does require high impedance injectors. You'd need to measure resistance on one of your injectors to know whether yours are high or low impedance.
Post by 331mustang on Jul 6, 2017 20:41:38 GMT -5
What injectors do you recommend?
Post by Stinger on Jul 6, 2017 21:11:33 GMT -5
Depends on what sort of power you're planning to make. That dictates how large they need to be and size dictates type as not all types are available in all sizes. So what's your expected power, or if you don't know, what's your setup?
Post by 331mustang on Jul 7, 2017 8:18:59 GMT -5
Dss 331, Anderson b31 cam, trick flow heads and intake Anderson power pipe prom racing mass air meter 77 and I plan on putting a nitrous kit on it
Post by Stinger on Jul 7, 2017 12:55:06 GMT -5
If your 42's are high impedance then they should be enough to support your goals, assuming the nitrous is a wet kit, not a dry kit. Otherwise we sell 60lb Siemens Deka injectors for $450 shipped, or flow matched race type FID525's which are 50lb/hr for $500 shipped. They are comparable to Injector Dynamics only cheaper.
If you're planning to run a dry kit then I'd need to know how large of a kit to know how much additional injector flow you'd need.
