safado
Boosted Newbie
Post by safado on Oct 9, 2017 12:40:16 GMT -5
Hello, I looking at a Stinger XS for a Windsor with a manual trans and a small shot of Oxide.. One of the questions I have is what ignition system can I use with it? Currently I'm looking at just the plain factory remote TFI dizzy off a 94+ truck... Can the distributor be used without the TFI? just the hall effect to the Pimp? If not, will the remote one work? probably just more wiring?
thanks
Post by Stinger on Oct 9, 2017 12:52:49 GMT -5
You can use TFI, DIS, EDIS, as well as just about anything else if configured and wired to do so.
Remote TFI is no different than TFI on the distributor as far as the ECU is concerned.
